USB board Mk3 and AYA II revisited (proposal)
Two projects proposal for 2018.
Another story about TDA1541A: 384 kHz
Can this old gem get there?
Back to the roots: 14 bits (of TDA1541A)
By measuring standard low level performance at -60 dBFS (dithered sine wave), there was practically no difference between its regular 16 bit, and this 14 bit “mode” of operation. Noise floor, on the other hand, is somewhat higher, roughly speaking 6-12 dB, and that is what you would expect, given 2 bits difference.
USB to simultaneous data or I2S converter, series 2
Audial USB interface second release. Now offered as both module and ready made device.
USB to simultaneous data (or I2S) board
Audial quality USB interface. At one side it connects to PC via USB port, and on the other it outputs “raw” PCM signal, in simultaneous data or I2S form.
Asynchronous USB to simultaneous data converter board, interest check
Asynchronous USB Audio Class 2.0, galvanic isolation, two oscillators, and reclocked simultaneous data output. With U.FL output connectors it would be adequate companion to AYA II 2014 or DS board, and of course the great possibility to connect PC to Model S MkIII.
AYA II DS, DIY edition
As announced a few months ago, we have another run of AYA II. This run, marked as DS, includes one update with respect to AYA II 2014: synchronous DEM clocking circuit is now more completely integrated, so it is not optional but integral part of this AYA II project.
AYA II 2014 DIY edition, second run
As an extension of original AYA II 2014 DIY edition offer, here is the second turn of AYA II 2014 orders.
AYA II 2014 DIY edition talks
Everything related to AYA II 2014 DIY edition building, parts and possible tweaks can be asked, discussed or shared at this page.
AYA II 2014 DIY edition interest check
As a result of initiative by several TDA1541A fans at diyaudio.com, AYA II DAC may re-appear in 2014.
