AYA III
PRODUCED IN 2009. THIS PAGE IS FOR REFERENCE ONLY.
Input:
S/PDIF
 electrical, 75 Ohm unbalanced; BNC connector (RCA adapter supplied); transformer coupled, with capacitively coupled ground; supported sampling frequencies up to 96kHz
Output:
Unbalanced (RCA), capacitivelly coupled, 2.1V RMS
Output Impedance:
160 Ohm @ 1kHz
Frequency Response:
Sin(x)/x equivalent:
@ fS=44.1kHz: 0dB @ 20Hz, -3.2dB @ 20kHz
@ fS=88.2kHz: 0dB @ 20Hz, -0.8dB @ 20kHz
Transient Response:
Clean, with no overshoot or ringing.
Absolute Phase:
Correct
Harmonic Distortion:
0.12% @ -6dBFS & 1kHz, I/V dominated
(mostly 2nd and 3rd harmonic)
0.02% @ -20dBFS & 1kHz, I/V dominated
0.7% @ -60dBFS & 1kHz, D/A dominated
Intermodulation Distortion (CCIR):
0.25% (19kHz+20kHz, -6dBFS each)
Mains voltage:
220-240VAC, 50-60Hz , IEC (C14) connector
(110-120VAC also available)
Measures (W x D x H):
277 x 180 x 72 mm (including knob, connectors and legs)
277 x 173 x 56 mm (excluding knob, connectors and legs)
Weight:
Approx. 3 kg
