Holo Audio Red and A-link compatibility
Quote from Is3 on 9 September 2024, 4:54 PMHello!
I have new streamer called Holo Audio Red.
Really fitting device to my Audial S5 rig. It's pure minimalistic design with one LED 🙂 - even configuration is very simple.
Currently using ALT2 configuration (which I believe corresponds to the PS Audio standard) over I2S.
I want to ask if other option are possibly compatible with "A-Link" mode? the description in S5 manual is bit different than Red streamer manual.
Page from manual below:
Hello!
Quote from Pedja on 11 September 2024, 6:53 PMThanks for reporting this.
Yes, it looks like ALT2 matches the PS Audio I2S standard.
ALT1 and ALT3 should fit the A-link I2S pinout for + signals, so the channels are not reversed, and the absolute phase is correct.
Terms LRCK (Left/Right Clock), which became more widespread, and WS (Word Select), used in the original Philips I2S specifications, are "synonymous", they denote the same signal.
Quote from Is3 on 11 September 2024, 8:18 PMJust tested. S5 switched to "SIM".
Result is the same on both ALT1 and ALT3 there is only sound in left channel and it's extremely distorted.
Quote from Is3 on 11 September 2024, 8:49 PMSo SIM switch position is used for connecting two S5/S5b for 4 channel operation?
Tested again on i2s mode and results are:
ALT1 = swapped channels.
ALT2 = using that on daily basis, working great.
ALT3 = Working properly.
So which is more aligned with your standard?
Btw. tested additionally upsampling and for ALT2 + ALT3 the highest possible value is 96kHz.
Quote from Pedja on 11 September 2024, 9:37 PMPractically speaking: mostly yes. The mode switch should be actually set to SIM to work with any source that outputs Philips simultaneous data protocol (and matches specified pinout and voltages), but it narrows down to the S5/S5b and AYA 5 devices (so two devices can operate as 4-channel USB DAC), and Audial USB Mk3 interface board, which was released only once, as a limited edition.
Regarding the Red configuration, I would expect the channels set properly in modes ALT1 and ALT3, because the LRCK signal at pin 7 is then positive, which fits A-link WS requirements.
ALT2 sets the negative LRCK signal to pin 7, which, when you connect it to A-link input, swaps the channels.
Also, ALT1 and ALT3 set the positive DATA signal to pin 1, as required by A-link specs.
ALT2 sets the negative DATA signal at pin 1, which, when you connect it to the A-link input, produces the inverted absolute phase (polarity) at the audio output.
So, I would expect ALT1 and ALT3 to operate properly with A-link input, set to I2S mode. It looks like the modes ALT1 and ALT3 are the same for PCM (I2S) output, and differ only in their DSD specs.
Yes, the highest expected FS for S5/S5b A-link input operating in I2S mode is 96 kHz.
