Audial S5b paired with Matrix X-SPDIF 2
Quote from PKay on 11 September 2024, 2:13 PMI have been using the the S5b with the Matrix DDC and in my system I find it to be significantly better than USB input directly from my computer which was a surprise. The Matrix has a Teddy Pardo PSU.
I could not reliably tell the difference between i2s and Coax in my system they were very similar. I was able to toggle between the 2 using a remote control.
Anecdotally I have heard a lot of people saying SPDIF and i2s were better than USB. I can highly recommend the Matrix.
Quote from Pedja on 11 September 2024, 8:40 PMIt is surprise to me, too. The S5b USB stage is of very high quality, but I will take your findings most seriously.
Also, can you please be more specific on the sonic differences?
Thanks.
Thanks.
Quote from PKay on 12 September 2024, 12:49 PMI'll give it a try. Reviewing isn't really my thing.
Firstly a bit about the Matrix 2
Onto Higher Level
The newly designed USB Audio Class 2.0 asynchronous digital interface X-SPDIF 2, inherited the excellent quality from its last generation. You can connect the digital audio stream receive devices through the newly added IIS port, to avoid the loss caused by digital signal protocol conversion. X-SPDIF 2 built-in high-quality femtosecond clock and FPGA processing unit, it can playback up to 32bit/768kHz PCM audio stream and 1bit/22.4MHz DSD audio stream.
More Powerful X-CORE
The new generation XMOS U208 is an 8 core digital signal processing unit, it has powerful multi-core and multi-threaded processing capabilities, and it is the industry's most advanced USB Class 2.0 digital audio solution by far.
FPGA Control Centre
The strong XILINX SPARTAN FPGA assist XMOS manage and assign the clock, processing DoP transcoding and JITTER reduction for IIS port.
Audiophile Crystal Oscillators
X-SPDIF 2 uses 2 Accusilicon high-quality femtosecond clocks as reference clock source, which work at the state of 44.1kHz, 48kHz and their multiple sample rate. The FPGA automatically control the frequency assignment and switching, and the femtosecond clock has independent ultra-low noise LDO power supply.
Multi-level LDO
The power supply units of X-SPDIF 2 are constructed by multi-level, multi-group LDOs and solid capacitors, they can filter out the superimposed noise from power supply effectively. All the circuit powered by low noise or ultra-low noise LDO, which avoided the hi-frequency switch noise caused by DC/DC circuit. You also can obtain high quality power from USB bus.
Configurable IIS Port
X-SPDIF 2 support different standard of IIS, it can compatible for different devices by configuring the IIS definition switch. The DoP converting function transcode DoP audio stream to native DSD stream output from IIS port.
External Power Supply Supported
X-SPDIF 2 has a power supply interface, you can add an external linear power supply to it. It will disconnect the USB bus power automatically when you connect it to an external power, then the X-SPDIF 2 can work with mobile devices.
CNC Aluminum Chassis
In order to get the best electromagnetic shielding performance, to minimize the impact of mechanical vibration, X-SPDIF 2 still followed the CNC aluminum chassis design. We are not afraid of the complicated design and process, to make sure your computer can output high quality digital audio stream.
Features
Powerful multi-core and multi-threaded processing capabilities
FPGA Control Centre
Multi-level, multi-group LDOs and solid capacitors
Specifications
TECHNICAL
Optical/Coaxial/AES
PCM 16-24Bit /44.1kHz、48kHz、88.2kHz、96kHz、176.4kHz、192kHz DSD64(DoP)
IIS LVDS
PCM 16-32Bit /44.1kHz、48kHz、88.2kHz、96kHz、176.4kHz、192kHz、352.8kHz、384kHz、705.6kHz、768kHz DSD64/128/256/(DoP) DSD64/128/256/512(Native) NOTE: Please see the X-SPDIF 2 user manual for the IIS LVDS definition.
System Support Windows7/8/8.1/10 system needs to install the supplied driver. Mac OS X10.6.4 or above without installing the driver. Most Android devices can be used via OTG cable. The iOS devices can be used via Lightning to USB Camera Kit.
POWER
Power Supply Specs USB bus power supply: 5V/500mA External power supply: DC 6~9V,≥800mA Power supply port: outer diameter 5.5mm; inner diameter 2.1mm (+ for inner, - for outer)
That's all the technical stuff that gives an idea of what is included.
For me the biggest difference is a warmer tone using i2s, the sound stage is bigger with the singer seeming to be taller and further back. It's hard to put into words but i2s is relaxing, I find myself enjoying the music more and not trying to over analyse. In my system the Coax input is pretty much identical, I can't really hear a difference between it and i2s. It takes one of the best Dacs I have heard to another level and I'm so pleased to have discovered the Audial Dac (I can finally get off the Dac treadmill). It takes me much closer to my vinyl system where the cartridge alone costs as much as the Dac.
I am using W11 with the latest version of Jriver.
My recommendation is to get one (possibly a loan) and give it a try.
Onto Higher Level
FPGA Control Centre
Multi-level LDO
Features
FPGA Control Centre
Specifications
TECHNICAL
Optical/Coaxial/AES
IIS LVDS
POWER
Quote from Pedja on 14 September 2024, 2:59 PMThanks for the comprehensive information.
As you probably know, the S5b USB stage is also an outstanding, master USB device with two low-jitter audio clocks fed by low noise supply, with galvanic isolation, all local linear supplies also for the USB decoding part, etc.
So I checked the Accusilicon clocks' specs, and it looks like they have about 7-8 dB lower phase noise than Crystek, all else being equal. I might also add that (I can't remember if I've ever told this publicly, so this might be the first time), the way the Crysteks are used in S5b improves their nominal specs for about 4-5 dB at low frequencies, but even then the Accusilicon could be a tiny bit better.
Also, the sonic difference you describe may be related to the I2S as a mode of operation. (S5b S/PDIF stage also communicates to the TDA1541A by I2S.) I know people who prefer I2S to simultaneous data protocol for TDA1541(A) for reasons that relate well to what you have written.
Anyhow, whatever the ultimate reason is, I would leave the setup the preferred way and enjoy it like that. The benefit of the S5b direct inputs is direct access to its D/A part from the external world so it can be tweaked and tailored further to personal preferences and particular systems.
I might once give a try to this DDC, although I do not think I have it nearby.
And, as a sidenote... I personally always strive to design all inputs, as well as the DAC as a whole, as good as possible. Recently I made a small unit, based on the last Audial USB Mk3 interface board (beside the A-link output from the USB board, it has an additional board providing LVDS I2S and S/PDIF output), both as a lab tool for S5b testing, and as a platform for experiments with different routing, modes, options, etc, and as a tool that helps to improve our understanding of how various parts affect the overall result.
Quote from PKay on 17 April 2025, 6:49 AMHi Pedja,
I have been watching the Eveyday Audiophile review and his comment about setting dither to 16bit at the software end caught my attention. For context I am running Jriver and I have upgraded to the Matrix X3 which has a slightly better i2s implementation. In order to reduce dither to 16 bit I had to select the WASAPI option as ASIO did not give me a choice.
Any suggestions for Jriver setup would be appreciated.
The DAC is still sounding so good.
Cheers,
Peter
Hi Pedja,
Cheers,
Peter
Quote from Pedja on 21 April 2025, 6:07 PMHello Peter,
The S5b USB stage enumerates itself as a 24-bit unit, so it does not force either dithering or truncation. This way, the use of dither is left to every user's preferences.
Some dithering techniques and algorithms are better than others, and I know some people prefer no dithering at all. I, for one, mostly do not use it for listening, but my reasons are partially practical ones (so I rather rely on so-called bit-transparent signals).
On the other hand, for DACs measurements, I often do use dithered signals, so the signal itself does not present itself as a limiting factor. The dither notably breaks the artefacts' signal dependency, achieving better linearity, at the expense of a somewhat increased noise floor. Most of the TDA1541A DACs' distortion graphs on this website (as well as the lab report for your unit) were taken using signals that employed dither, usually triangular, with noise shaping respecting the Fletcher-Munson curve. It mostly matches the one demonstrated here:
https://www.audialonline.com/articles/glossary/#ditherRegarding the audio playback/listening, it is usually on the playback software (or OS/driver), or possibly their plug-ins, to perform this task, and the final result will notably depend on its quality. As far as I understand, WASAPI should not perform dither, so if you set its output to 16-bit, it should rather only truncate longer binary words (and S5b itself will do this anyhow). However, there may be more to this here, related to J-river, which I am not familiar with, so I can not advise about it.
Anyway, I would advise experimenting with possible options, and the option that sounds the best will be the best. 🙂
Regards.
Hello Peter,
Regards.
Quote from Pedja on 22 April 2025, 11:56 AMSorry, I overlooked that it was your primary interest. But most of what I wrote above applies the same.
The I2S LVDS and A-link inputs are one-way connections (as opposed to USB, which is two-way). Also, these are the "direct" inputs, so the data (and clocks) you send there will be at the TDA1541A input.
So, the source will not "know" the actual DAC bit-depth, and with 20- or 24-bit sources, the TDA1541A will truncate everything after the 16th bit. Dither, if deemed advantageous, should be performed on the source side.
Quote from gryphongryph on 22 April 2025, 12:22 PMCan I join this thread for a moment, Pedja I have the S5b and I am using Roon for my music, serving my Primare dac that up samples everything to 192 in my living room upstairs, my music room downstairs I use the S5b.
For the best sound quality should I down sample everything in Roon to 16/48 as I do now or just let Roon output the higher sample rates?
Thanks
Thanks
