As I wrote in my earlier post about the amplifier power, the power is the product of two things: the voltage and the current. The higher the loudspeaker impedance (typically 6 Ohm or more), it is rather the voltage that sets the power limit. Consequently, the lower the loudspeaker impedance (4 Ohm or less), the chances are the amplifier will first reach its current limit.
Since its release, the Model A has been offered in 25 W and 50 W versions, the only difference between them being the supply voltage. A 50 W version also had a transformer dimensioned adequately to suit the current demands. In any case, the Model A was able to provide 5 A, and such capabilities were enough to respond to typical loudspeaker demands for current.
Still, even though it did not happen very often, some Model A users also had speakers with an impedance that hit below 4 Ohm. In such circumstances, and considering the regular home listening environment and usual loudness demands, more current was necessary. That is why the Model A units shipped in 2015, as opposed to earlier devices, can provide 10 A. Therefore, at 4 Ohm, these units double their claimed power at 8 Ohm, and can also work well with loudspeakers impedance as low as 3.5 Ohm.
It is also important to note that this change, while it enhances the Model A capability, is done in a manner that does not compromise its sound quality.
